Hi all and thanks in advance.
i wanted to sort surfaces based on their areas.
my final values are not correct.Where is my mistake?
u want to sort them by ascending order of their area?
yes. so i can take the max value .
try list.sort node instead of SortIndexByValue node
i also trying different levels if something is wrong but i dont get where is the mistake
Can you share your files?
use SORT&GROUP BY KEY INSTEAD OF List.SortByKey
which package is that?
DanEDU Dynamo
If all you want is to get the largest area why no just use “List.MaximumItem”?
to use list.max item i need to convert surface information to area . after the maxitem out put will be a number but i need surface to maniplate later on.
But when you have the maximum area using List.MaximumItem, you can use a simple boolmask to find the surface with that one/multiple with the biggest surfacearea?
i didnt know that also dont know how to
exactly the one!
