List.Indexof Value -1
Why yes if the data from excel output is -1, while if it is made from within dynamo he managed to retrieve the index of it, even though the data is the same integer
Hi @ikhsan.pc you are sure its the same object type ?
oh okay, different object type, in order to use index of how?
you can fix it with math ceiling or floor in that case
thank you very much solved
