Keep empty items in the list and remove first/last items in the list
Hi, guys.
I’m trying to get items except first and last and keep the structure of the list
But I think I missed lacing or level settings, please give me any advices
Hi @jaeho
I’ve made a python script which removes the first and last element in a list. It doesn’t keep the structure owned by the input list. It returns only elements contained in a list if the length of the list is bigger than two.
import sys
input_list = IN[0]
output_list = []
def remove_fist_last_item(input_list):
	if any(isinstance(item, list) for item in input_list):
		for item in input_list:
			if isinstance(item, list):
				remove_fist_last_item(item)
		if len(input_list) > 2:
			output_list.append(input_list[1:-1])
OUT = output_list
Perhaps this is also useful?
Hope that helps,
Mark
@Meychik @Mark.Ackerley Hi, Thank you for your solutions the problem is both approaches don’t keep the Empty List…
It seems to work as you wanted it to be.
import sys
input_list = IN[0]
lst = [1,2,3,4]
def remove_first_last_items(input_list):
				remove_first_last_items(item)
			input_list.pop(0)
			input_list.pop(-1)
OUT = input_list
Hi, Thank you so much for your solution. Can I ask one more?
Is it possilbe flatten these hightlighted items??
Try this.
Hi@Meychik,
Thank you for your solution again! :+1:
a node version
20 septembre forum anglais_2022-09-20_11-31-41
Cordially
christian.stan
@christian.stan Thank you for your solution. I haven’t thought about the codeblock like that for amount. Good approach :+1:
