Hi, I have too many CAD blocks need to make as revit families! Is there any way to batch create families by cad block with dynamo? Thank you very much first !
Usually, I need to create a new family file, then import the cad block, then explode the imported CAD block, and finally save it as a completed family file.
Now I want to know how to use Dynamo to complete batch family file creation.
This’re CAD files of furniture(Change ‘dwg’ format to ‘zip’ please).dwg (2.0 MB)
I’m sure there are other ways to do this, but I used this approach when I had to convert 100s of .objs to .rfas. This should work with dwgs as well.
- Separate all blocks you want to import to separate files. You can wblock all blocks with a lisp like this: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/batch-wblock-of-blocks-in-drawing/m-p/789693/highlight/true#M15351
- Create a “template” rfa. It’s an empty rfa file, where you will import one block. Set up categories, parameters, in this “template”
- Create a copy of the template rfa named similarly to the exported dwgs. You can use a batch like this:
@echo off
SETLOCAL EnableDelayedExpansion
SET FILEEXT=DWG
SET TEMPLATEFILENAME=template
for /R "%~dp0" %%f in (*.%FILEEXT%) do (
echo processing: %%f
copy "%~dp0\%TEMPLATEFILENAME%.rfa" "%~dp0%%~nf.rfa"
echo "%~dp0%%~nf.rfa">> "%~dp0filelist.txt"
Maybe you can also do this in dynamo, I like to do file manipulations in batch or bash, they are quicker.
- Create a dynamo script which imports dwgs which has the same name as the current file:
To import dwgs I used the dwg nodes from the GeniusLoci package: - Use revit batch processor to cycle through the created rfa files: https://github.com/bvn-architecture/RevitBatchProcessor
This workflow doesn’t create true revit geometry from the imported dwgs, they will be only imports. You just have to figure out what you really want, add it to the script, and cycle through the script with BatchProcessor.
Thank you for helping me!!!
I try it first
Apologies for bringing this post back to life. I am using your process above and came across an issue. The imported 3D CAD only shows up on the ref. level. I understand you have to specify a view in the Import DWG node, so I’m wondering if there’s a way to have the import show up on all views?
Hello, and welcome to the forum!
This is a limitation in the GeniusLoci Import Dwg node. You can change this behavior manually: open the node and edit the python code manually. Change line 29 from True to False:
options.ThisViewOnly = False
Now imported dwgs will become 3D elements.
Hi Nick,
You will find the updated Import Dwg node in the Genius Loci package version 2021.6.3.
Thanks Alban, it has worked for me! Cheers!
Does any one care to share their .dyn to reverse engineer? Help out a Dynamo novice learn some more? =)
