Is it possible to debug Dynamo python code using JetBrains PyCharm?
Hi All,
For my Python coding, I’m using JetBrains PyCharm (as my IDE) like following:
Is there a way to use the debugger of the JetBrains PyCharm to improve error recognition? or just looking the OUTPUT through a watch node?
Thanks in advance!
I don’t think you can get pyCharm to debug the code that ultimately needs to run in Dynamo and Revit environment to be verified. There is no way that I know of, to attach pyCharm to Revit/Dynamo to execute code in debug mode. So, yes, you can debug by watching errors coming out of the python node in Dynamo.
cc: @Gui_Talarico I think you had a workaround for that with the debugger package though. Can you chime in?
Thanks @Konrad_K_Sobon. So, I guess an alternative way could be the explained by @Gui_Talarico in this post:
I’ll give it a try.
Thanks!
Indeed that’s as close to a debugger as you will get as far as I know. It’s pretty awesome if you ask me.
Yes, great job!
Added more info on the Console related to pycharm:
For the most part, this Console is good enough for me.
If you want true debugging (step in/out/over) you can look into pydev or winpdb.
These both offer remote debugging and are able to communicate remotely with a remote debugging server.
Thanks @Gui_Talarico for taking the time to answer here and the other thread. I’ll give it a try !
