Introducing Agentic workflows in Dynamo
Looks great!
Hi, I would love to test this!
Hi @Aidanne.Forcier :waving_hand: Please dm me your preferred email to add you to the Alpha project.
@achintya_bhat I would be interested in getting alpha access to this .
@SejalShinde2TQED send @achintya_bhat a DM directly as noted in the initial posting and in several of the follow-up posts. The team needs some personal information in order to get you access which should not be directly posted on the forum.
I’ll send a DM. For anyone just landing here, the chat window is a bit of a treasure hunt.
Awesome!
I try to message you, but a error expect in the platform
I want to check the IA Agent
Can you please post the error that happens when you click the link in the original post? I believe it was due to your new user status which I think I have cleared.
This is the error that appears. I appreciatte your help
So @jacob.small who do I email?
… Joking.. sorry couldn’t resist. :smiley:
I’ve messaged Achintya :slight_smile:
This is the first (and perhaps last?) time I think I’ve used this…
:face_with_symbols_on_mouth:
Challenge accepted!
Ah moose… did I miss the part where I need Dynamo 3.6? :frowning:
I guess I need newer than Revit 2025 then?
Assuming you are fully patched you should have 3.3.
Unfortunately agentic node, and assistant use dynamo 3.6 or newer. So unless you want to mess about with your install, sandbox is probably your tested for now. Although 2026 has 3.6.1
Ah! Good shout out @john_pierson. Totally misread that message.
Altho really more :sob:
Hi Jacob, I am having the same personal message error. I would also like to test the agentic dynamo workflow.
Adding to the thread, I also have a error sending the message.
This is great. How can I join this test? How to DM you?
