Searching into the previous lines of the code, I did this:
resp = []
for i in range(len(inicio)):
resp.append(List.Flatten(inicio[i],1))
inicio = resp
so Inicio came formatted from this point as a list with nested lists which were flattened.
Could this be the seed of the problem?
Here is he inicio sequence for best understanding:
inicio = []
fin = []
for capa in segmentos:
aux = []
aux2 = []
resp = []
resp2 = []
for tramo in capa:
aux.append(List.FirstItem(tramo))
aux2.append(List.LastItem(tramo))
resp.append(aux)
resp2.append(aux2)
aux = []
aux2 = []
inicio.append(resp)
fin.append(resp2)
resp = []
inicio = resp
resp = []
for i in range(len(fin)):
resp.append(List.Flatten(fin[i],1))
fin = resp
for k in range(len(ind_pisos)):
for j in range(len(inicio[i])):
if ind_pisos[k] > inicio[i][j] and ind_pisos[k] < fin[i][j]:
aux = list(inicio[i])
aux.insert(j + 1, ind_pisos[k])
aux2 = list(fin[i])
aux2.insert(j, ind_pisos[k])
inicio[i] = aux
fin[i] = aux2
pass
That could very well be. Could you show me all the import statements at the top of your code?
import Autodesk.DesignScript.Geometry
clr.AddReference('DSCoreNodes')
from DSCore import *
I see, so it must be the DSCore method that caused it. Oh well, glad to hear you found a workaround
Yeah!. Now I’m figuring out how to flatten a nested list to get the exact data structure, avoiding List.Flatten. Any ideas?
You mean to flatten in python without the DSCore method?
resp = []
inicio = resp
resp = []
fin = resp
this part, avoiding List.Flatten()
Flatten in python is actually not that easy as the depths of lists can vary a lot. So you would have to come up with some kind of recursive function to tackle every kind of depth level.
In your case this should work I think:
@T_Pover Thanks a lot for your time! This thread really taught me a lot today!.
