IndicesOf Python node
Thanks to you guys, I could learn Dynamo easily.
And now, I can write Python code. Fun!!!
Here is a simple one I wrote. It’s about IndexOf node which I leaved a question about a few days ago here.
IndexOf returns only first index of matching items.
This simple code returns multiple matching indices.
이미지 2
Love python.!!
Hello Hyunu Kim ,
We are tracking this issue under MAGN-6190
I will get back to you once it is fixed.
Keep Using Dynamo!
Thanks,
Ritesh
I tried your script for my problem
http://dynamobim.com/forums/topic/why-is-indexof-andor-not-working/
but i get an empty list do you know why: connected the list to int[0] and the point to int[1]
IndicesOf
Check this post:
http://dynamobim.com/forums/topic/remove-null-values-in-code-blocks/
Hi guys i have a similar problem with extracting and mapping data, i hope you can help me
What im trying to do is the following:
1-i have created a parameter in the revit families and assign a unique code to each
2- in excel i have the same code and a price for each code
3- im trying to map the cost from excel to each of the revit families using the code i gave them
im stuck getting in the point shown in the image, i try the CADesigner solution but its only for finding one value in a list, i need to map a list against a list. any ideas?
Thanks! i have learn a lot in this forum and in the Hyunu youtube channel.
5D
Check if this script works for your problem:
