Hello, so i have been trying to script if the original value is larger than 0.495 then it takes the value 0.495, but if smaller than 0.495 then it takes the original value for a revit panel on facade.
When I have set up the value > 0.495 code block it has worked stating the correct values as true or false with the same amount of items as original list.
However when i connect to the IF node, using the
value > 0.495 to ‘test’
0.495 number block to true
original list to false
it has created a list of lots of items and where it has recognised it to be true previously and so these items should now be showing at 0.495, it is showing the original number. Does anyone know what is going wrong here and could help please?
thanks
