How to use List.Transpose Method in Python Script Node Dynamo?
I’m learning to translate a dynamo script and compact it into a single python node. I need to use the List.Transpose method… how to write it in python? and what references i need to add to be able to run the method?
I already tried using ironpython List but got error no transpose method
also tried import DSCore but cannot find any documentation about the class and methods of it
the original script
#new user can’t upload dynamo script
currently stuck at this
# import Revit Services
# import Revit API
clr.AddReference("RevitAPI")
clr.AddReference("System")
clr.AddReference('DSCoreNodes')
from DSCore import List as Dlist
dataEnteringNode = IN
# Place your code below this line
if hasattr(IN[0], '__iter__'):
	bbox = IN[0][0]
	bbox = IN[0]
minpoint = bbox.MinPoint
maxpoint = bbox.MaxPoint
combinep = [minpoint,maxpoint]
Plist = List [Point]()
for i in combinep: Plist.Add(i)
combinep.Transpose()
#Plist = List.Create(minpoint,maxpoint)
OUT = bbox,
Better to use the Python method zip than import the list.transpose method.
zip(list1,list2, list3…)
Thanks for the reply. Using the Python zip method for list manipulation can be a solution.
But can you explain the logic of the Dynamo List.Transpose method?
And how do I translate it into Python zip list and for loop to achieve the same result?
For an example use this problem
transpose list
A little google:
Using zip() in Python
Python’s zip() function is defined as zip(*iterables). The function takes in iterables as arguments and returns an iterator. This iterator generates a series of tuples containing elements from each iterable. zip() can accept any type of iterable, such as files, lists, tuples, dictionaries, sets, and so on.
Passing
See
Using the Python zip() Function for Parallel Iteration – Real Python.
Good luck
Hello, you have the power of DesignScript also as a possible way with a function
code block:
def info(bb:var)
i=BoundingBox.MinPoint(bb);
j=BoundingBox.MaxPoint(bb);
l=Line.ByStartPointEndPoint(i,j);
centroid=Autodesk.DesignScript.Geometry.Curve.PointAtParameter(l,0.5);
dx=j.X-i.X;
dy=j.Y-i.Y;
dz=j.Z-i.Z;
rep=dz==0?true:false;
_Key=["Centroid-->","Width-->","Lenght-->","Height-->","BB Flat-->"];
_Val=[centroid,dx,dy,dz,rep];
return DesignScript.Builtin.Dictionary.ByKeysValues(_Key,_Val);
Cordially
christian.stan
I reviewed this in the 6th Dynamo office hours, posted here: https://m.youtube.com/playlist?list=PLdlF7MirPEC2yNFTGymESd3t7Xosfk9c2
Zip basically does the same, as noted in the link above.
Thanks @jwroelofs for informing the zip(*iterables) method
Here is my code to emulate the result of the dynamo List.Translate node
But I still cannot figure out how to implement dynamo node input list level selection to affect the result
maybe @jacob.small can help with this problem
data = IN[0]
def maxlistdepth(list):
	maxdepth = 0
	for i in list:
		newdepth = len(i)
		if maxdepth < newdepth:
			maxdepth = newdepth
	return maxdepth
def addnull(list,maxdepth):
	for i in list:
		while len(i) < maxdepth:
			i.append(None)
maxdlist = maxlistdepth(data)
addnull(data,maxdlist)
OUT = list(zip(*data))
Another solution is to import DSCore Builtin Dynamo Library to use the List.Transpose method
import sys
from DSCore import List as DList
data = IN[0]
transpose = DList.Transpose(data)
OUT = transpose
The Results are the same
Thanks, @christian.stan for Design.Script solution. I learned from you that CodeBlock can be used to make functions only without any input or output and the function can be used in other CodeBlock
Hereby I attach the .dyn
Python Transpose.dyn (12.8 KB)
This is Bering a bit off topic, but there is no need for the transpose in your graph. You want the center, width, and length of a bounding box, so…
Typing off my phone, but hopefully this makes sense if it doesn’t just work with the default inputs.
bbList = IN[0]
results = []
for bb in bbList:
    minPnt = bb.MinPoint
    maxPnt = bb.MaxPoint
    vect = Vector.ByTwoPoints(minPnt, maxPnt)
    width = vect.X
    length = vect.Y
    height = vect.Z
    cent = minPnt.Add(vect.Scale(0.5))
    data = [cent, width, length, height]
    results.append(data)
OUT = zip(*results) #returns the lists in order of centers, then widths, then lengths, then heights. If you want stuff groups by bounding box just use OUT = results
