Hi Everyone. I’m trying to write a script to assign comment results to a common family of models. However I can only create a parameter filter. Is there any way I can change the result in the red circled part of the image? Hope everybody help please…!
import System
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
view = doc.ActiveView
categories = List[ElementId]()
categories.Add(ElementId(BuiltInCategory.OST_GenericModel))
filterRules = List[FilterRule]()
parameterFilterElement = ParameterFilterElement.Create(doc,"Comments",categories)
para = ElementId(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
filterRules.Add(ParameterFilterRuleFactory.CreateEqualsRule(para, "Comments", True))
for i in filterRules:
parameterFilterElement.SetElementFilter(i)
OUT = True
