Hello
I am trying to make a roof fascia
i don’t know how to make a reference array
This is a part of the code
RoofExtrusionLines are lines wich i used to create a roof (roof by extrusion)
refArrays = []
outList = []
for lines in RoofExtrusionLines:
rArr = ReferenceArray()
for l in lines:
rArr.Append(Reference(l))
refArrays.append(rArr)
FasciaNew = doc.Create.NewFascia(Fascia, refArrays)
OUT = Fascia
I don’t see anything wrong with the code above. Are you importing everything from the Revit API to allow you to use the ReferenceArray constructor directly? e.g.
clr.AddReference('RevitAPI')
ref_array = ReferenceArray()
Hello
The problem is that i feed lines
Those lines i used to create the roof by extrusion
but i don’t no how to get reference of that roof to create a refference array wich i need to create the fascia
fascia.dyn (28.4 KB)
Hello cgartland
I solved the problem
index = [3,4,7,8]
fascias = []
opt = Options()
opt.ComputeReferences = True
roofSolid = footprintRoof.get_Geometry(opt)
edgeRefs = []
temp = []
for i in roofSolid:
edges = i.Edges
for j in edges:
edgeRefs.append(j.Reference)
ref3 = edgeRefs[3]
for i in index:
ref = edgeRefs[i]
FasciaNew = doc.Create.NewFascia(Fascia, ref)
fascias.append(FasciaNew.ToDSType(False))
OUT = fascias
