How to load a Package in to python
How can i load a package like BimorphNodes into Python?
i tried this :
# Enable Python support and load DesignScript library
import sys
sys.path.append(r'R:\Dynamo\PACKAGES\bimorphNodes\bin')
sys.path.append(r'R:\Dynamo\PACKAGES\bimorphNodes\extra')
#import BimorphNodes
bm = sys.path.append(r'R:\Dynamo\PACKAGES\bimorphNodes')
bm = sys.path.append(r'R:\Dynamo\PACKAGES\bimorphNodes\bin')
bm = sys.path.append(r'R:\Dynamo\PACKAGES\bimorphNodes\extra')
import BimorphNodes as bim
dataEnteringNode = IN
# Place your code below this line
OUT = bm
Yes, you can:
#Copyright 2019. All rights reserved. Bimorph Consultancy LTD, 5 St Johns Lane, London EC1M 4BH www.bimorph.com
#Written by Thomas Mahon @Thomas__Mahon info@bimorph.com Package: BimorphNodes
#Follow: facebook.com/bimorphBIM | linkedin.com/company/bimorph-bim | @bimorphBIM
import System
from System.Collections.Generic import Stack
import sys
sys.path.append('ADD YOUR PATH TO THE BIMORPHNODES PACKAGE BIN FOLDER HERE')
clr.AddReference('BimorphNodes')
import Curve
curveList = IN[0]
stack = Stack[Autodesk.DesignScript.Geometry.Curve]()
for crv in curveList:
    stack.Push(crv)
ptList = Curve.IntersectAll(stack)
OUT = ptList
Thanks Thomas
it worked
why is that little r needed before the path in : sys.path.append(r’R:\Dynamo\PACKAGES\bimorphNodes\bin’) ?
The r prefix is telling it that the following string is a string literal, otherwise forward slashes are not interpreted as characters but instead they have a special function for interjecting strings with a new line for example: \n. That’s problematic in file paths so r tells it not to look for any of these special characters just treat it all as a string. More info here:
https://docs.python.org/2.0/ref/strings.html
Thank you
