How to get thermal conductivity and specific heat
Hi, I want to get thermal conductivity and specific heat of wall materials from Revit. Does anyone have an idea?
Thank you
Check this article here. I believe it should resolve your issue Modify the Material ThermalConductivity Parameter
Thank you so much
Problem solved :slight_smile:
Thank you once again
Did you find the search field on top-right of this screen? :slight_smile:
In case not, you probably didn’t read the forum guidelines yet:
Welcome to the forum!
