for any reason, i can`t get an empty value to cero… because for any reason it is a string…
so i multibly the “empty string” by 1 and i get null and i can replace it by 0…
is there a better way ? when i get integers i expect to work with integers… it seems to be it is not always the way…
KR
Andreas
hello, it is still possible to create a function as well
function:
def transform_int(a)
return a==""?0:Math.Floor(a);
cordially
christian.stan
@christian.stan ,
i tried this also and it works… hmmm
to create trouble in the mind
cordially
christian.stan
I would use the simple if statement here as it is the most robust and least susceptible to data type errors (ie, if you get ‘one’ as a value instead of 1). The design script is as posted by @Draxl_Andreas: x==“”?0:x;
