How to get all spaces of a zone
Hi all! I’m looking for a way to have all spaces of a chosen zone. The ideal it could be to obtain a list in which they are all listed and divided for zone of appartenance.
Thanks to everyone in advance!
Hi @Lucaly1994,
This should work :
#By Nick_Boyts
clr.AddReference('RevitAPI')
# Import ToDSType  (bool) extension method
# Adds ToProtoType, ToRevitType geometry conversion extension methods to objects
# Import Element wrapper extension methods
from Revit.Elements import *
zones=UnwrapElement(IN[0])
if not hasattr(zones, '__iter__'):
    zones = [zones]
output=[]
for i in zones:
	spaceSet = []
	spaces = i.Spaces
	for j in spaces:
		spaceSet.append(j)
	output.append(spaceSet)
OUT =output
Hi Alban, I’m really sorry but I don’t know anything about python so I can’t understand what i have to do. Can you explicate me better this? I have to do a custom node? I have to write this in a code block? How can I set input and output?
Thanks very much!
Here is a graph with the python script.
Zones HVAC.dyn (3.5 KB)
Thanks very much Alban! Very kind!
You’re welcome.
I just saw that there is already an existing node in the MepOver package : the Zone.Spaces node.
You can mark the topic as solved.
Hi Alban,
I have another question regarding the zones and space.
I want to use Dynamo/ python to assign each space to a separate zone, or combine certain zones. But I am not sure which function I should use. Do you have any chance know that?
