How to filter the list of loaded & orphaned & not found xref by their status from all file references using dynamo
Is there any dynamo script or python code which can filter the loaded & orphaned & not found xrefs by their status from all file references through dynamo and make a separate list.
While I couldn’t find a node in Dynamo (haven’t looked in 2025 yet) you may look at the GetHostDwgXrefGraph method in a Python node. I managed to get all loaded xrefs including attached xrefs where the results are listed as lists, if a list is longer than 1 the next xrefs are attached xrefs. unloaded xrefs are ignored. It is a fairly untested script so no idea how well it works.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
import traceback
res = []
with adoc.LockDocument():
    with adoc.Database as db:
            try:
                xg = db.GetHostDwgXrefGraph(False)
                for n in range(xg.NumNodes):
                    tmplist = []
                    db2 = xg.GetXrefNode(n).Database
                    if not db2 == None:
                        try:
                            xg2 = db2.GetHostDwgXrefGraph(True)
                            for n2 in range(xg2.NumNodes):
                                if not xg.GetXrefNode(n).IsNested or xg == None:
                                    if n2 > 0:
                                        tmplist.append(xg2.GetXrefNode(n2).Name)
                                        tmplist.append(xg.GetXrefNode(n).Name)
                        except:
                            err = traceback.format_exc()
                            tmplist.append(err)
                        res.append(tmplist)
            #t.Commit()
            except:
                res.append(err)
            pass
OUT = res
