How can I get spatial element from room in Dynamo PythonScript ?
Im want to use spatial element method to room :
http://www.revitapidocs.com/2017.1/e73594e8-23aa-899f-82fb-3490def8ece2.htm
Im get All rooms in view:
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
doc =DocumentManager.Instance.CurrentDBDocument
collector=FilteredElementCollector(doc, doc.ActiveView.Id)
rooms=collector.OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType().ToElements()
And later i want to get a spatial element from room :
spatial_rooms=[UnwrapElement(i).SpatialElement for i in rooms] ???
OUT = spatial_rooms
in the end, I want to get surfaces areas of the walls , floors, ceilings from all rooms without the area of including windows and doors
So the Element.Geometry node?
if we will use Element.Geometry node then
we will get solids of rooms and then we can get the surfaces of this solids.
but I need to get the surface finish, probably… because I want to get the wall area of current room without the area of including windows and doors
What is the end goal? couod you subtract door and window areas from the surfaces?
