I can access info of a family of all pipes in a view i have coalited in a list using a dynamo node but i would like to do it inside a python script as the way i am doing it at the moment is resulting in to many nodes in my dynamo script (as I’m accessing multiple shared parameters across the family) .
Thanks for the reply, I am doing it as you shown above but i have a lot of parameters to access as it is for a fabrication document. As I am accessing so much information there ends up being an awful lot of lists/nodes.
I am using some python script nodes in my code already and I was hoping to figure out how I can access the shared parameters within the python node to somewhat clean up the dynamo script.
I have tried a few different lines of code to access the parameters but I cant seem to get the code to run once i try and access a specific parameter within the python code. So i have to access the shared parameter values with a python node and feed it into the code as a list. This is making the code very bloated and i would love to avoid this if possible
