Hi
I would appreciate some help understanding if / how to use the methods and properties from the Revit API in python.
If possible I would like to use a python node to replicate these nodes from archiLab.
I can find these methods in the Revit API
https://www.revitapidocs.com/2020/49c1091b-87f1-164d-cd50-c383d642fb00.htm
In a python Script node I can call Autodesk.Revit.DB.ImageTypeOptions(‘path’)
I am unsure if / how I can use Python to set the Resolution Property
Is there a way to use python to achieve this?.
Thank you in advance
