Help retrieving all elements from linked models intersecting a Bounding Box
I am trying to retrieve all elements from linked models that intersects a bounding box. The code I have only retrieves the elements from the active model. See below for current code. I am relatively new to Dynamo and code writing and I would greatly appreciate any help anyone can offer.
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘System’)
clr.AddReference(‘RevitNodes’)
#Functions for list handling
def ProcessList(_func, _list):
return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def ToRevit(item):
return item.ToRevitType(True)
if isinstance(IN[0], list):
bblist = ProcessList(ToRevit, IN[0])
bblist = [ToRevit(IN[0])]
def collectElementsInBB(bb):
outline = Outline(bb.Min, bb.Max)
filter = BoundingBoxIntersectsFilter(outline)
collector = FilteredElementCollector(doc, doc.ActiveView.Id).WherePasses(filter)
return [e.ToDSType(True) for e in collector]
OUT = ProcessList(collectElementsInBB, bblist)
