Just started dabbling into Dynamo and need your help. I want to filter out specific view names and then add a parameter to the category of rooms to that view. Is this even possible?
I want to filter out views that contains “RDS” (Room Data Sheets) and then set a parameter within Rooms to it. But I can’t filter out RDS from View Names to begin with. Am I missing something?
I did this and got it to work! - But I guess I just realized now that what I’m trying to achieve doesn’t work. But hey! It’s still a step. Thanks for your help.
Knhan try this method, this is the cleanest way to remove the null values, and will result in no warnings when you run the script.
I am not sure what the ‘null’ views are, I assume they relate to something at a system level in Revit (as you can see on top, they have no parameters as they are a null).
You can use the ‘Element Name’ node instead of get parameter to save a few pieces of code too!
