I am trying to set a global parameter value using python but it doesn’t work. While I am able to GetValue() or GetType I still cant assign new value.
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import ReferencePointArray
# Import DocumentManager
doc= DocumentManager.Instance.CurrentDBDocument
dataEnteringNode = IN
j = IN[0]
h = UnwrapElement(j)
D = h.GetValue().Value
m = h.GetType()
q= h.GetOrderedParameters()
h.SetValue(10.0)
OUT = D
Looks like your parameters types might not match. What kind of value is it expecting? What do you get back with GetValue?
To set the parameter value you need to construct a ParameterValue as seen in the API docs for the SetValue() method
Here is the constructor for a DoubleParameterValue and you can determine what ParameterValue class you need to construct by using .GetType() after .GetValue()
Additionally, you’ll need to start and close a transaction to change the parameter value.
Something like this should work:
hValue = Autodesk.Revit.DB.DoubleParameterValue(10.0)
h.SetValue(hValue)
newVal = h.GetValue().Value
OUT = newVal
Make sure to import the transaction manager as well
