Hi everyone,
Thank you for your interest in this topic.
I feel like I should give you guys a bit more context. I am trying to “upgrade” a working Dynamo graph written mostly in IronPython 2 to CPython3.
This graph takes an ExcelFile from my users and :
- creates new shared parameter
- loads the parameter into the project
- OR updates the categories associated to it if the parameter already exists (for it is the only writable property of the
ElementBinding)
To do so, at some point in my code, I need to create an ExternalDefinitionCreationOptions which takes two arguments, the parameter name which is a String and the parameter type which is an object of type Autodesk.Revit.DB.ParameterType
My process is to read the string from the Excel file, to collect all ParameterType with System.Enum.GetValues(ParameterType), go through all of them comparing the excel input with the ParameterType name (through str(ParameterType) ) so I can store the ParameterType of class Autodesk.Revit.DB.ParameterType in a new list
I would like to get the same result in CPython3 that I get in IronPython2
The issue seems to be the one @c.poupin pointed out but the proposed workaround in the other topic doesn’t work for me.
With :
dictParameterType = dict(zip(System.Enum.GetValues(ParameterType), System.Enum.GetNames(ParameterType)))
I get this error :
Unable to cast an object of type 'System.Int64' into a type 'System.String'
And building the dictionary the other way around :
dictParameterType = dict(zip(System.Enum.GetNames(ParameterType), System.Enum.GetValues(ParameterType)))
Returns once again a System.Int64 object when getting values (eg: dictParameterType["Text"] returns 1 )
In the pythonnet GitHub, someone gives this workaround :
from Tests import TestClass, TestEnum
a = TestClass()
a.EnumMethod[TestEnum](TestEnum.FirstValue)
But I am unable to figure out how I can adapt it to my case. Especially because Autodesk.Revit.DB.ParameterType is the class I am looking for and the Enum at the same time
Trying other proposed solutions did not work so far.
I hope someone can help me figure this one out and thanks again for your help !
