I am trying to select a set of lines using data-shapes and extract the length parameter, but it retuns as string:
It’s because you are feeding the line stylename (string) into the get parameter node and not the actual line. Data-Shapes has a node “All Lines of LineStyle”. Use that between the list flatten and get parameter node.
