Get Views - Remove nulls in python
the OUT Dynamo Wrapper is capricious with certain objects
here a solution
ueWrapper = next((m for m in clr.GetClrType(Revit.Elements.ElementWrapper)\
				.GetMethods() if m.Name == "Wrap"), None)
if ueWrapper is None:
	raise Exception("Error Method", "method 'Revit.Elements.ElementWrapper.Wrap' not found")
views = FilteredElementCollector(doc).OfClass(View).ToElements()
outlist = []
for i in views:
	iswrapable = Revit.Elements.ElementWrapper.Wrap(i, True)
	if iswrapable is None :
		outlist.append(ueWrapper.Invoke(None, (i, True) ))
		outlist.append(i)
OUT = outlist
