Get Views - Remove nulls in python
Hello Dynamo Friends :slight_smile:
In some python scripts i have the problem that there are many nulls in my output list:
So i would like to avoid getting these nulls or remove those nulls.
I tried “is not None” and “!= None” without success:
outlist = []
views = FilteredElementCollector(doc).OfClass(View).ToElements()
for view in views:
	if view != None:
		outlist.append(view)
OUT = outlist
Happy about any advice :slight_smile:
@gerhard.p ,
i have no solution just a direction. My idea is filter by object Type and kick out else… …but it does not work :confused:
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
outlist = []
otyp = []
for i in views:
	otyp.append(i.GetType())
for view in otyp:
	if view == Revit.Elements.Views.AreaPlanView:
		outlist.append(True)
	elif view == Revit.Elements.Views.Legend:
	elif view != Revit.Elements.Views.ScheduleView:
		outlist.append(False)
	elif view == Revit.Elements.Views.View:
	elif view != Revit.Elements.Views.AxonometricView:
	elif view != Revit.Elements.Views.CeilingPlanView:
	elif view != Revit.Elements.Views.StructuralPlanView:
	elif view != Revit.Elements.Views.PerspectiveView:
	elif view != Revit.Elements.Views.DraftingView:
	elif view != Revit.Elements.Views.FloorPlanView:
	elif view != Revit.Elements.Views.Sheet:
	elif view != Revit.Elements.Views.SectionView:
	elif view != Revit.Elements.Views.View3D:
OUT = outlist,otyp
Oh now it came to mind, that @Alban_de_Chasteigner has a List.Clean node that also contains more information on this topic:
Clean list or list of lists of all None or Empty lists in Python - Stack Overflow
def ClearList(primList):
    result = []
    for sublist in primList:
        if sublist is "":
            continue
        elif sublist is None:
            continue
        if isinstance(sublist, list):
             sublist = ClearList(sublist)
             if not sublist:
                 continue
        result.append(sublist)
    return result
OUT = ClearList(IN[0])
You could also use the filter(None, list) function.
outlist = []
OUT = filter(None,views)
@Alban_de_Chasteigner ,
the NULLs still remain
grafik
the OUT Dynamo Wrapper is capricious with certain objects
here a solution
import sys
import System
ueWrapper = next((m for m in clr.GetClrType(Revit.Elements.ElementWrapper)\
				.GetMethods() if m.Name == "Wrap"), None)
if ueWrapper is None:
	raise Exception("Error Method", "method 'Revit.Elements.ElementWrapper.Wrap' not found")
outlist = []
for i in views:
	iswrapable = Revit.Elements.ElementWrapper.Wrap(i, True)
	if iswrapable is None :
		outlist.append(ueWrapper.Invoke(None, (i, True) ))
		outlist.append(i)
OUT = outlist
@c.poupin ,
that works well!
But i have no idea whats going on :smiley:
Whats a wrapper?
@gerhard.p ,
So i found out that it´s the converting of 3D views to elements with the FilteredElementCollector is the problem:
And i solved that by dropping 3D viewtypes:
outlist=[]
for view in views:
	x=view.ViewType
	if view.ViewType != ViewType.ThreeD:
OUT = outlist
Probably 3D view templates.
An old « bug » of Dynamo for Revit.
Hi @gerhard.p maybe try also skip the project browser and system browser that are in your list. Cheers
I provide my python function version to collect all views in a document and also removing the funny nulls but showing the all the corresponding view types in the document, that means 3D View templates , system browser, project browser are available with ID :exploding_head:.
I tried in a project and I got this list of view types:
[0] CeilingPlan
[1] Detail
[2] DrawingSheet
[3] Elevation
[4] FloorPlan
[5] Legend
[6] ProjectBrowser
[7] Schedule
[8] Section
[9] SystemBrowser
[10] ThreeD
[11] 3DViewTemplate
this how it displays in dynamo node the results:
thanks to the suggestion of @c.poupin I could do some investigation and make it work as wanted:
import sys
import System
def WrapUnwrapElements(elements):
    # Get method Revit.Elements.ElementWrapper.Wrap
    outlist = []
    for i in elements:
            outlist.append(ueWrapper.Invoke(None, (i, True)))
            outlist.append(i)
    return outlist
def GetViewType(view):
	if hasattr(view, "ViewType"): return str(view.ViewType)
	else: return None
def GetAllViews(doc):
    collector = FilteredElementCollector(doc).OfClass(View).ToElements()
    # Apply the WrapUnwrapElements function
    wrapped_views = WrapUnwrapElements(collector)
    allviews = [view for view in wrapped_views if isinstance(view, Autodesk.Revit.DB.View) or 'View3D' == str(view)]
    view_dict = {}
    for view in allviews:
        view_type = GetViewType(view)
        if view_type is None:  # Handle views with None type
            view_type = "3DViewTemplate"
        if view_type not in view_dict:
            view_dict[view_type] = []  # initialize the list for this view type
        view_dict[view_type].append(view)  # append the view to its respective list
    return view_dict
def GetAllViewTemplates(doc):
    templates = [view for view in wrapped_views if (isinstance(view, Autodesk.Revit.DB.View) and hasattr(view, "IsTemplate") and view.IsTemplate) or 'View3D' == str(view)]
    view_dict = {}
    for view in templates:
    return view_dict
OUT = {"All Views in Document": GetAllViews(doc), "All View Templates in Document": GetAllViewTemplates(doc)}
