Get Total Volume Result Data For Material List
I’m trying to create a function in Python that will produce earthwork and material volume reports for all the materials in a sample line group (similar to the _AeccGenerateQuantitiesReport command). I have managed to get the total volume result data for each material list in a sample line group but struggling to find a method in the .net API that exposes what’s in the total volume result data.
Attached is a drawing to test the python script with. Any suggestions would be much appreciated.
SLG vol.dwg (1008.9 KB)
# Load Python standard libraries
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
clr.AddReference('Civil3DNodes')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acApp
# Import references for Civil 3D
# Import references for PropertySets
from Autodesk.Aec.PropertyData import *
from Autodesk.Aec.PropertyData.DatabaseServices import *
# Declare global variables
aDoc = acApp.DocumentManager.MdiActiveDocument
ed = aDoc.Editor
cDoc = CivilApplication.ActiveDocument
# Functions
def get_slg_vol_result():
    This method gets the total volume result data for material list
    associated with a sampleline group.
    :param mappingGuid:
    :return: Volume result data.
    global aDoc
    global ed
    global cDoc
    # Instantiate empty lists
    mNames = []
    mGuids = []
    matNames = []
    volumes = []
    result = []
    error_report = None
    try:
        # Get the active document in the AutoCAD session:
        with aDoc.LockDocument():
            with aDoc.Database as db:
                    # Get the objectId collection of all Alignment objects in the drawing
                    alignmentId = cDoc.GetAlignmentIds()
                    # Get the alignment
                    for a in alignmentId:
                        alignment = t.GetObject(a, OpenMode.ForRead)
                        # Get the object collection of all sample line groups
                        # belonging to alignment
                        for s in alignment.GetSampleLineGroupIds():
                            slg = t.GetObject(s, OpenMode.ForRead)
                            # Get the SLG QTO Mapping Names
                            mNames = slg.GetQTOMappingNames()
                            # Get the SLG mapping global unique identifier
                            for m in mNames:
                                mGuid = slg.GetMappingGuid(m)
                                mGuids.append(mGuid)
                            # Get material names in mapping and total volume
                            # result data for material list
                            for n in mGuids:
                                matName = slg.GetMaterialNamesInMapping(n)
                                matNames.append(matName)
                                volume = slg.GetTotalVolumeResultDataForMaterialList(n)
                                volumes.append(volume)
                                result = [mNames, mGuids, matNames, volumes]
    except:
        import traceback
        error_report = traceback.format_exc()
    if error_report == None:
        return result
        return error_report
# Output
OUT = get_slg_vol_result()
Hi @Alex.ColeAAFHE
Are you trying to get Cum. Fill Volume?
Hi @Kulkul - for starters it’s fantastic to see what I’m trying to achieve is possible in Python :grinning:. To be clear I’m trying to access all the results used to create these reports:
  1. earthwork.xsl for the Cut and Fill material list.
  2. Select Material for the material list
What class and method/property are you using to get that information? Is it located in .net API or COM?
It’s available in .NET API. Check this out:
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/net/Autodesk__Civil__QTO__DatabaseServices__QTOResultType.htm
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/net/!!MEMBEROVERVIEW_Autodesk__Civil__QTO__DatabaseServices__QTOVolumeResult.htm
@Kulkul
Hello, is it possible to sharing Python Script to calculate the quantities of backfilling and cutting ?
it’s a great job
@Kulkul
Great job! Any chance you can share the python script?
Hi @kovacsv
Could this link help you?
To access the review of quantitie
Hi @hosneyalaa,
Yeah I found that link as well, and I can get the cut and fill values now, but I need the structural volumes list (calculated from corridor shapes), but I don’t know how to use QTOResultType Enumeration:
Any ideas, how to change the QuantityTakeoffResult to MaterialStructureVolume?
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
dataEnteringNode = IN
aDoc = Application.DocumentManager.MdiActiveDocument
editor = aDoc.Editor
    :param mappingGuid:
    global aDoc
    global ed
    global cDoc
    mNames = []
    mGuids = []
    matNames = []
    volumes = []
    volumeres = []
    result = []
    error_report = None
    try:
                    # Get the alignment
                            for m in mNames:
                            for n in mGuids:
                                ##volumetype = volume.kMaterialStructureVolume
                                qtoSectionalResult = volume.GetResultsAlongSampleLines()
                                length = qtoSectionalResult.Length
                                for i in range(length):
                                    qtoAtStation = qtoSectionalResult[i]
                                    volumeresatstation = qtoAtStation.VolumeResult
                                    fill = volumeresatstation.IncrementalFillVolume
                                    volumeres.append(fill)
                                result = [mNames, mGuids, matNames, qtoSectionalResult,volumeres]
                                return result
    except:
        import traceback
# Output
Hi
I will try with you through the great code who wrote
I don’t know how to use it But I will try to find something
Hi @kovacsv
Can you see this discussion? Can you help us with something? to thank
Well in my understanding this is a dead end. As for now, I think it is not possible to get structure volume numbers directly from QTO via the API.
Another approach we are thinking of, is to somehow get the shape areas from AppliedAssemblies–>CalculatedShapes and calculate the volumes from there, but this needs time, as I have designing duties besides my free time programming activities :smiley:
Hi @kovacsv
Please look at this
