i use LookUp but i can`t find the error, how can i access the host from my tag ?
KR
Andreas
hosts = []
for i in elements:
t = GetTaggedReference.Reference(i)
hosts.append(t)
OUT = hosts
KR
Andreas
hosts = []
for i in elements:
hosts.append(t)
OUT = hosts
What version of Revit? That method was replaced in 2022.
GetTaggedReference Method (revitapidocs.com)
Your syntax also doesn’t look right in this application. It should be i.GetTaggedReferences()
there is a small recomendation
i will later make a Element or ElementIds
elements = UnwrapElement(IN[0])
hosts = []
for i in elements:
t = i.GetTaggedReferences()
hosts.append(t)
OUT = hosts
KR
Andreas
The warning tells you exactly what’s going on and your previous output confirms it. GetTaggedReferences()
now returns a list so you have to go one step deeper to interact with each reference.
i use Revit 2022… so i can use Reference.
or i can go straigt forward in the list…
KR
Andreas
Your code shows that you’re using References though. And the error still confirms that you have a list of lists.
its fine so elementid is not Id and is not a string, i tricksed a bit
door_tags = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_DoorTags).WhereElementIsNotElementType().ToElements()
references = []
for i in door_tags:
references.append(i.GetTaggedReference())
elements = [i.ElementId for i in references]
ids = [int(str(i)) for i in elements]
OUT = ids
