Is there some “reverse point at parameter” option? I have some points on polycurve, and I need to extract their parameters, cause further I need to insert points at half distance between every two points (they aren’t equdistanced).
What parameter are you looking to get? Some data that you want to copy to a newly created point?
Hello Rade,
Have you tried the node “Curve.ParameterAtPoint” ? Though my experience wit PCs and point creation at parameters is a bit mixed. You might get better results if you convert the parameters into distances with “Curve.DistanceAtParameter” and then create the mid points with “Curve.PointAtDistance”.
Tnx for answers, Curve.ParameterAtPoint did the job
