Get out port data in Revit Api
Hi, I’m Revit api developer and I’m tring to develop a new add-in using Dynamo.
I run .dyn file with this code.
IDictionary<string, string> journalData = new Dictionary<string, string>
    {JournalKeys.ShowUiKey, false.ToString()},
    {JournalKeys.AutomationModeKey, true.ToString()},
    {"dynPath", dynPath},
    //{JournalKeys.DynPathKey, dynamoJournal},
    //{JournalKeys.DynPathExecuteKey, true.ToString()},
    {JournalKeys.ForceManualRunKey, true.ToString()},
    {JournalKeys.ModelShutDownKey, true.ToString()},
    //{JournalKeys.ModelNodesInfo, false.ToString()},
//get all loaded assemblies
var loadedAssemblies = AppDomain.CurrentDomain.GetAssemblies();
//find the Dynamo Revit one
var dynamoRevitApplication = loadedAssemblies
    .FirstOrDefault(a => a.FullName.Contains("DynamoRevitDS"));
//create our own instances of these things using reflection. Shoutout to BirdTools for helping with this.
object dInst = dynamoRevitApplication.CreateInstance("Dynamo.Applications.DynamoRevit");
object dta = dynamoRevitApplication.CreateInstance("Dynamo.Applications.DynamoRevitCommandData");
dta.GetType().GetProperty("Application").SetValue(dta, uiApp, null);
dta.GetType().GetProperty("JournalData").SetValue(dta, journalData, null);
object[] parameters = new object[] { dta };
dInst.GetType().GetMethod("ExecuteCommand").Invoke(dInst, parameters);
DynamoRevit.RevitDynamoModel.ForceRun();
foreach (NodeModel outputNode in DynamoRevit.RevitDynamoModel.CurrentWorkspace.Nodes.Where(x => x.IsSetAsOutput))
And I want to get out port data like next screen shots.
How can I get out port datas?
@baekdi
what do you mean by port data ? extracting X,Y,Z values ?
No, that means the “Outputs” data in Dynamo Player.
Hi @baekdi not sure i understand, is it as Andreas mention ? with the xyz value separate in players output ?
No, results vary depending on node type.
I can get that output values by this code :
foreach (PortModel outport in node.OutPorts)
    MirrorData mirror = node.GetValue(outport.Index, engine);
    var data = mirror?.Data;
//////////////////////////NodeModel Class////////////////////////////////
public MirrorData GetValue(int outPortIndex, EngineController engine)
    return engine.GetMirror(GetAstIdentifierForOutputIndex(outPortIndex).Value).GetData();
/////////////////////////////EngineController Class///////////////////////
/// <summary>
/// Returns runtime mirror for variable.
/// </summary>
/// <param name="variableName">Unique ID of AST node</param>
/// <returns>RuntimeMirror object that reflects status of a single designscript variable</returns>
public RuntimeMirror GetMirror(string variableName)
    lock (macroMutex)
        RuntimeMirror mirror = null;
        try
            mirror = liveRunnerServices.GetMirror(variableName, VerboseLogging);
        catch (SymbolNotFoundException)
            // The variable hasn't been defined yet. Just skip it.
        catch (Exception ex)
            Log(string.Format(Properties.Resources.FailedToGetMirrorVariable, variableName,
                ex.Message));
        return mirror;
It can get value when the outport has a single value like summary of EngineController.GetMirror().
I can’t get outport values in list format.
How can i do?
Hi @baekdi
you can use the GetElements() method and the StringData property (MirrorData class)
a test in Revit 2025 (with macro)
C# Code
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Dynamo.Graph.Nodes;
using Dynamo.Applications;
using ProtoCore;
using Newtonsoft.Json;
using System.Dynamic;
using Dynamo.Configuration;
using Dynamo.Logging;
using System.Linq;
namespace LauncherScrit2
   [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
   [Autodesk.Revit.DB.Macros.AddInId("C234F93B-EFCB-4A43-AEB7-7F995E539D37")]
   public partial class ThisApplication
      private static Dynamo.Engine.EngineController engine;
      // define logger variable
      private static DynamoLogger logger = new DynamoLogger(new DebugSettings(),
                                                    Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments),
                                                    false,
                                                    false,
                                                    false);
      private void Module_Startup(object? sender, EventArgs e)
      private void Module_Shutdown(object? sender, EventArgs e)
      public void DynamoMacroRun()
         UIDocument uidoc = this.ActiveUIDocument;
         Document doc = this.ActiveUIDocument.Document;
         UIApplication uiApp = this;
         string resultOut = "";
            {"dynPath", @"C:\Users\poupincyril\Documents\Test_Macro_Script.dyn"},
         Dynamo.Models.DynamoModel rdm = (Dynamo.Models.DynamoModel)dInst.GetType().GetProperty("RevitDynamoModel").GetValue(dInst, null);
         engine = rdm.EngineController;
         Dynamo.Graph.Workspaces.HomeWorkspaceModel wkspace = (Dynamo.Graph.Workspaces.HomeWorkspaceModel)rdm.CurrentWorkspace;
         logger?.Log("------------------------------------------", LogLevel.File);
         // suscribe node
         IEnumerable<Dynamo.Graph.Nodes.NodeModel> nodes = wkspace.Nodes;
         wkspace.Run();
         try
            foreach (Dynamo.Graph.Nodes.NodeModel node in nodes)
               if (node.IsSetAsOutput)
                     logger?.Log($"Process Node : {node.Name}", LogLevel.File);
                     foreach (Dynamo.Graph.Nodes.PortModel outport in node.OutPorts)
                           ProtoCore.Mirror.MirrorData mirror = node.GetValue(outport.Index, engine);
                           IEnumerable<string> valuesData = mirror.GetElements().Select(p => p.StringData);
                           string json3 = JsonConvert.SerializeObject(new object[] { node.Name, valuesData}, Formatting.Indented);
                           resultOut += "\n" + json3;
                           logger?.Log(json3, LogLevel.File);
            TaskDialog dialog = new TaskDialog("Dynamo");
            dialog.MainInstruction =  "Run Success";
            dialog.ExpandedContent = resultOut;
            dialog.Show();
               logger?.LogError(ex.Message);
               TaskDialog.Show("Dynamo", "Run Failed");
