Get HostElement of a BoundaryConditions Element in Python
I am new to using the Revit API and would like to get the HostElement of a BoundaryConditions Element in Python. Here is what I tried:
grafik
Import RevitNodes
Import Revit elements
from Revit.Elements import *
Import DocumentManager
import System
myBc = IN[0]
OUT = myBc.LevelId
Any tips on how to import the right ‘parts’ of the API?
Edit: I am using Revit 2016 and Dynamo 1.3
You can add the lines :
# Import RevitAPI
clr.AddReference('RevitAPI')
P.S : I’ve no idea if your script will work.
Hi Alban,
thank you for your answer, unfortunately I still get the same warning (I tried it with “LevelId” instead of “HostElement” in the original post)
You need to import Autodesk.Revit.DB.Structure, and unwrap the element. Read about unwrapping and more here: https://github.com/DynamoDS/Dynamo/wiki/Python-0.6.3-to-0.7.x-Migration
@Einar_Raknes thank you, that helps alot!
