hi guys
i’m trying to retrieve the geometry of a family element which has only one detail element
the result is
No geometry
but while i snoop i can see the solid geometry help me out
hi guys
the result is
When accessed via Dynamo, detail components do not have geometry but their family types do.
A few things to note:
Are you doing this in the family file or in a project?
family loaded into project
Ah. You’re using a detail item inside a model item. These are excluded typically. I’ll see what I can dig up but this may not be possible with your current family setup.
Thanks jacob
This may work out for this particular family but it is not generic solution i have different families of the different shape in same template
Then likely you’ll have to move to using another method of modeling your content, or build a custom node to expose that content. Short of that you can get the topmost face of the model content and work with that after pulling onto the desired plane; get all model content and project onto a plane to create surfaces (this could be VERY computationally taxing), or if stuff is really complex creating a detail component which has the shape and flexibility you need and placing that programmatically atop your other current family instances and pull the content from there. Wish I had better news for you.
Hope this works Thanks Jacob
What is the category of your family ? If it is a Generic Annotation or a Detail Item category, it is possible to retrieve the 2D geometry in the correct location with the help of the API.
It’s classified as furniture in this case. ![]()
Jacob is Right but your reply help to understand more clearly thanks Alban
The masking regions don’t appear to be supported by the API.
So the solution from @jacob.small is therefore the only one.
The geometry of the symbolic lines can however be retrieved if necessary.
EDIT :
Looks like I was too quick in my tests. See the post by @c.poupin below.
Alban thanks a lot for spending time on it this is one of a sample i have many families similar to this…so this wont work. but thank a lot have a good day
hello,
a Python solution with specify the view in Geometry Option (the detail elements are only visible on certain views)
clr.AddReference('RevitAPI')
elem = UnwrapElement(IN[0])
outsurface = []
outedges = []
outlines = []
#get the actual view where the Detail Element is Visible
view = doc.ActiveView
op = Options()
op.View = view
geoms = elem.get_Geometry(op)
for geoinst in geoms:
if isinstance(geoinst, GeometryInstance):
geosymbs = geoinst.GetInstanceGeometry()
#or only get Symbolgeometry
#geosymbs = geoinst.GetSymbolGeometry()
for geoelem in geosymbs:
if isinstance(geoelem, Solid):
for face in geoelem.Faces:
outsurface.extend(face.ToProtoType())
for edge in geoelem.Edges:
outedges.append(edge.AsCurve().ToProtoType())
if isinstance(geoelem, Line):
outlines.append(geoelem.ToProtoType())
OUT = outsurface, outedges, outlines
result without symbolic lines in Family (only masking regions)
result with symbolic lines
its not working alban
