<p style=“text-align: left;”>I’m trying to get all view templates in a file.</p>
<p style=“text-align: left;”>I don’t understand why this code doesn’t work.</p>
<p style=“text-align: left;”></p>
<table>
<tbody>
<tr>
<td>import clr
clr.AddReference(‘RevitAPI’)
import Autodeskclr.AddReference(“RevitServices”)
views = FilteredElementCollector(doc).OfClass(View)
viewlist = list()
for view in views:
if view.IsTemplate == True:
viewlist.append(view)
OUT = viewlist</td>
</tr>
</tbody>
</table>
Hi Antony Mcphee, i think your code is ok when use method if view.IsTemplate == True, just one thing’s not yet right in your code is : INDENT in your code.
Thanks @Antony_Mcphee for the start, I found a few items in the header that were mixed up and characters not functioning. Try this. My first test has nulls, so need to review further. Get List of All View Templates.
clr.AddReference('RevitAPI')
from RevitServices.Persistence import *
dataEnteringNode = IN
viewlist = list()
for view in views:
OUT = viewlist
as much as I’m learning to love
python archilab has a great solution for this
yes, but those do not create a list of view templates. you have to pick them one at a time. not useful for my workflow. I did come across those in my search. Desired output was a list though.
well i guess you could go round about, and get all views, then put them through “is view template” node.
Edit: I was incorrect, the nodes listed above do provide a list of the view templates in the project file.
I stand corrected, not enough coffee yet I guess. Thank you.
Would you be able to elaborate a bit further on how to use GetByType node to retrieve view templates?
from the archilab package you can use View Type and View.GetByType check out this forum post for more details
