Hello Nick,
thank you for your help with this code! Do you know if it is possible to change the binding categories of the parameters?
From where i get Element.Category custom node
Element.Category+ custom node from Clockwork doesn’t work on shared parameter element
Good day
Nick_Boytz python code helped me solve my issue, and I don’t see a code solution to the OP, so I share a solution in C#
Thanks…
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
class Cmd_ReturnParameterCategories : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
Application app = commandData.Application.Application;
Document doc = commandData.Application.ActiveUIDocument.Document;
BindingMap bindingMap = doc.ParameterBindings;
DefinitionBindingMapIterator iter = bindingMap.ForwardIterator();
iter.Reset();
Definition definition = null;
while (iter.MoveNext())
definition = iter.Key;
if (definition.Name == "CategoryName")
InstanceBinding binding = (InstanceBinding)bindingMap.get_Item(definition);
foreach (Category c in binding.Categories)
TaskDialog.Show("t", $"{c.Name}");
break;
return Result.Succeeded;
