Get all categories MEP with corresponing IfcEntities, how?
so my AI try does not work!
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import BuiltInCategory, Category, CategorySet
# Get all categories in the document
categories = doc.Settings.Categories
# Create a dictionary to store the IFC entities and their corresponding Revit categories
ifc_entities = {}
# Iterate through each category
for category in categories:
	if category.AllowsBoundParameters and category.CategoryType == CategoryType.Model:
		if category.HasMaterialQuantities:
			ifc_entity = category.get_Parameter(BuiltInParameter.IFC_ENTITY_LABEL).AsString()
			ifc_entities[ifc_entity] = category.Name
# Print the IFC entities and their corresponding Revit categories
output = {}
for ifc_entity, revit_category in ifc_entities.items():
	output.append(f'{ifc_entity}: {revit_category}')
OUT = output
there is still some trouble
background is i want to create a schedule for category! with 2 parameters (BuiltIn)
phase created and Family and Type
PyCreateSchedule.dyn (43.2 KB)
KR
Andreas
I don’t have time to dig into this today, but it would help if you also provided an IFC model to test in with some of your standard elements and known edge cases (if any).
you can grab MEP model from golden nugget f.e. @jacob.small , finally i need this schedules to implement in our office template…
or handout the script to planers.
also to have some kind dictionary {ifc:rft} would be great
KR
Andreas
MEP_Dataset_COMPLETE.rvt (6.2 MB)
…the buildinParameter i can`t get…
clr.AddReference('System')
catname = []
for c in categories:
	catname.append(c.Name)
OUT = catname, categories
need i to import a library to load ? like IfcOpenShell
KR
Andreas
Just a note that these settings will vary from export to export as the mappings are customizable, so you can’t really rely on one dictionary forever. It’ll be a good base but it isn’t going to be static.
For a given category Revit you can pull in the IFC
Type with this method: GetIFCClassNameByCategory Method
Note this uses a new namespace so you will have to import that as well. Also unlikely that gpt will help here - Google will be your friend.
for info, we can find a mapping IfcClass ⇔ Revit Categories into the Autodesk interoperability addin
