Get a function into Python Script as an input?
Is there any way to get a function into Python Script as an input?
fPython
hi mehmet, yes of course you can use functions in python nodes!
  1. internal functions are like:
def flunwrap(a):
#load input flattened and Unwrapped
for x in a:
for y in x:
elements.append(UnwrapElement(y))
return elements
to use it, just call it like:
flunwrap(IN[0])
it is even possible to use external functions! that is what makes live a lot easier! :wink:
how will it work?
  1. create a path to your personal library:
libpath = 'd:/Daten/ARCHITEKTUR/DYNAMO/Python-Codes/'
library = ‘2015DynamoLibrary.py’
  1. create the execfile reference:
execfile(libpath+library)
in your library file the syntax is like:
def flunwrap(a):
"load input flattened and Unwrapped"
for x in a:
for y in x:
return elements
you see, almost the same as in a python node (as far as i found out using a comment in the first line of a definition in an external file will be handled as message and has to be embraced by “”)
greatest advantage in day to day use: less typing as most of your functionsf can easily be generalized.
better enviroment for python coding in external editors :slight_smile: :slight_smile:
Passing nodes as functions to Python used to work in Dynamo 0.6.3 (and it was awesome!!!), but is currently not supported:
Is it now possible to use Functions as inputs in python scripts?
maybe this wasn’t the answer you were looking for…
but it is is quite fun
node base python.dyn (37.1 KB)
