i want to know can i use dyanmo for generative designing ? if yes then how or if not then which program ive to learn for generative designing
@kamalakhtar736 You should look in to T-Splines.
When you say “generative design” do you mean using search heuristics (like Autodesk Within) or parametric design, because there’s quite a big difference?
From my understanding searching heuristic or coming up with iterations is level of parametric designing, i mean in parametric designing we use variables which define limit of a system and condition of its operation. in generative designing same variables are used but program come up with various result which we can edit. please correct me if I’m wrong
thanks, will look into this.
The terms have been blurred over the years and used interchangeably to mean the same thing; you’re right that there are some cross-overs (which may be partly to blame) but they represent two very different methodologies.
Here’s one - not necessarily academic - way of defining it:
Parametric design
Known end goal (result is already known), which allows the result to be manipulated directly within a set of predefined constraints (sliders, handles etc)
Generative design
Unknown end goal (unpredictable results), which can be manipulated indirectly within a set of predefined conditions (change environment conditions) - reliant on incremental generational improvements to find a solution, typically in the form of an evolutionary algorithm
Which method are you looking to implement?
Dear @kamalakhtar736
You could Try Optimo, and looking for the research of Acustamo, by Andrea Vannini http://dynamobim.org/forums/topic/acustamo-released/ and https://andreaarch.wordpress.com/
or
Project Teaser by Nate Hollan https://vimeo.com/23061345. (Gh world with Galapagos and Octopus)
I’m agree with @Thomas_Mahon Generative hasn’t a specific goal, it comes an holistic view and a bottom up system. (Not like the Parametric such as Moretti or Musumeci https://www.youtube.com/watch?v=XNW7dGxNfWk)
Try to read Toni Kotnik _Digital Architectural Design as Exploration of Computable Functions, or have a look to some example like:
https://www.hda-paris.com/project/climate-ribbon-tm-miami-usa/ CLIMATE RIBBON
Energy Roof,Perugia by Coop Himmelb(l)a.
Autodesk created Project Akaba, I never tested unfortunatly…let me know if it could be useful to your research
Or better if you want to follow our champion @john_pierson try Project Fractal http://sixtysecondrevit.blogspot.it/2016/09/project-fractal.html
i was looking forward to find a way designing which inc-operate both, i mean we give input and constrains to our program and in output it will generate series of options which satisfy our need.
thanks for sharing this.
It is my pleasure…if you need more help let me know
actually i’m writing dissertation report on generative designing through bio-mimicry and i’m looking for case studies or research work .if you can help me with that then it will be very helpful.
Hi @kamalakhtar736 I am also doing dissertation on Generative design, would you help me please.
Yes I’ll help you if I can
How I can contact you?
Kamalakhtar736@gmail.com my email id
