Generating Python Stubs
Very often there are requests for how to get python stubs for IDEs - this is not always straight forward and a bit fiddly. I have written a python script to assist making this task easier.
  • Requires an install of pyRevit
  • IN[0] is the output directory
  • for VSCode add these lines to settings.json
    "python.analysis.extraPaths": [
        "C:\\<path to stubs directory>",
    "python.autoComplete.extraPaths": [
Stubs code
import sys
import traceback
from os import path
import System
# Add references for stubs
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
clr.AddReference('PythonStubsBuilder')
from PythonStubs import PythonStubsBuilder
def get_assemblies():
    return {
        assembly.GetName().Name: assembly
        for assembly in System.AppDomain.CurrentDomain.GetAssemblies()
Requires install of pyRevit
https://pyrevitlabs.notion.site/Install-pyRevit-98ca4359920a42c3af5c12a7c99a196d
Refer to pyRevit GitHub repository which is the primary source for this code
https://github.com/eirannejad/pyRevit/blob/master/extensions/pyRevitDevTools.extension/pyRevitDev.tab/Developer%20Tools.panel/Generate%20APIStubs.pushbutton/script.py
# References for stubs
refs = [
    "ProtoGeometry",
    "RevitNodes",
    "RevitServices",
    "RevitAPI",
    "RevitAPIUI",
assemblies = get_assemblies()
ref_dict = {ref: assemblies.get(ref).Location for ref in refs}
dest_path = IN[0]
if not isinstance(dest_path, str):
    raise TypeError("IN[0] is not a path string")
output = []
for k, v in ref_dict.items():
   try:
       stubs_path = PythonStubsBuilder.BuildAssemblyStubs(
                    v,
                    destPath=dest_path
       output.append('Generated stubs for {} -> {}'.format(k, stubs_path))
   except:
       output.append('Failed generating stubs for {}\n{}\n{}'.format(k, v, traceback.format_exc()))
OUT = output
@Mike.Buttery ,
you mean auto-complete based on Revit version in Dynamo Python window ! yes
grafik
in PyCharm it is a dream
how does it work? in my case i got errors
is this refered to my Revit folder ?
in PyRevit Toolbar it works smooth
KR
Andreas
The warning is to do with the windows .net System
PythonStubsBuilder is from pyRevit - that is why it is a requirement
Which version of Revit and Dynamo are you using?
@Mike.Buttery ,
grafik
Revit 2024, pyRevit is up to date
PythonStubsBuilder is part of pyRevit or have to import it extra ?
Ok, i think i understand, my Stubs are working in PyCharm, so dynamo can just use PyRevit content.
KR
Andreas
pyRevit has it’s own version in Dev tools which is also usable, however I have provided additional references to using the Dynamo API and RevitSevices that pyRevit does not cover
@Draxl_Andreas
I’m not at my workstation - the warning you get confuses me a bit as CurrentDomain has been part of .net for a very long time.
Perhaps try this
for assembly in System.AppDomain.GetAssemblies()
What I am doing here is using .net to get the dll file path for the reference so users don’t have to find it themselves. The stubs will also be current Revit & Dynamo version you are using.
I’ll have a deeper look in the new year when I am back from a break as I was going to attempt to extend it to C3D and AutoCAD.
Cheers
