Generate floors using shaft boundaries
Hello people
I hope you are all well.
I’m trying to mount my processes in Dynamo to save time and make less clicks.
There is a routine that I would like to generate.
This consists of modeling floors through the perimeter that is generated with a shaft.
This is because when we have a project that is reform or rehabilitation, we have to carry out demolition and new construction phases, the shaft itself does not recognize the phases well, so it does not recognize the demolition phase for a shaft.
I want Dynamo to recognize the boundaries of the shafts and model the type of ground it needs to put it into the knockdown phase.
If someone can help me with this it would be a great advance, because Autodesk still does not take care of this problem.
@i.soler , hi
Can you share some screenshots`?
Hi Draxl.
in this script i make floor with boundaries of Rooms
I imagine that the process is similar but identifying the boundaries of the shaft.
I really don’t know where to go to achieve it. if you can help me it would be great
