Generate a single Subregion from a large number of curveLoops
I’m trying to generate siteSubregion through Python. In fact, I can already do this with the help of the code provided by PowellDesign.
https://forum.dynamobim.com/t/creating-a-subregion-then-using-it-to-shape-edit-a-floor/31108
In the code he provided, every time curveLoop generates a new Subregion. But what I expect is to make multiple sets of curveLoop generate a single Subragion.
The following is my attempt to modify the code provided by PowellDesign, and I swear it succeeded several times based on the same data! But in most cases it is paralyzed. I don’t know what went wrong.
@_yoyo
Try this:
SiteSubRegion.Create(doc, List[CurveLoop](curveloops), host.Id)
I seem to have found a key factor that caused the “SiteSubRegion Method” to fail. This method does not seem to allow the specified “curveloop” to intersect. When I try to offset all Polygons inward by 0.01 meters and delete the Polygons that have self-intersections, everything works fine.
I don’t know if I solved the problem correctly, but everything looks good from the current results. Thank you for your reply!
I’m posting the final code here, with a slight modification, for reference and in case somebody needs it someday.
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Architecture import *
import System.Collections.Generic
# Get input variables
subregions = UnwrapElement(IN[0])
host = UnwrapElement(IN[1])
def Func_subregions(L2):
# Init variables
	curveLoops = []
	createdSubRegions = []
	# Get groups of curves (exploded polycurves!) and creates per group a SubRegion
	for i in L2:
		# Init CurveLoop for every curve group
		x = CurveLoop()
		# Iterate the seperate curves -> convert type to Revit Type -> add to CurveLoop
		for j in i:
			x.Append(j.ToRevitType())
		curveLoops.append(x)
	if SiteSubRegion.IsValidBoundary(curveLoops):
		# Create SubRegion out of the CurveLoop group and add its to 'createdSubregions'
		newSubRegion = SiteSubRegion.Create(doc, curveLoops, host.Id)
		createdSubRegions.append(newSubRegion.TopographySurface)
	return createdSubRegions
# Output
if IN[2]:
	newList = []
	newList.append(Func_subregions(subregions))
	OUT = newList
	OUT = "set IN[2] to True to run"
the output does not work with multiple sublist of curves, it shows only the first, although it creates many subregions as the given curve list group
