Folder Structure from dynamo
Hi everybody,
I need to get the folder structure from given path? The result should be a list with sublist of folders, without files.
Are there any node to do that? similar to file path or directory path?
Thanks a lot!
Have you tried String.Split ? I think a file path is understood by Dynamo as a string.
Edit : looks like I misunderstood the question.
Capture
You could also play with using “Directory.ContentsAll” from Orchid :slight_smile: Displaying all files in a directory…
( “*” means search for all) :slight_smile:
Thanks Jonathan, thats what I need
Jonathan, I need the sublist of folder too, in the next post is the solution! Thanks.
