I am trying to find what a floors offset is from its host level.
Given this is an instance item, my first issue is that I cant only call instances- it is also calling types of all floors in the project. So my first question is now can I only all active instances.
For the sake of this example, I only recorded floors after index 10, as I knew these were the instances.
My second challenge, and this is part of a bigger project, I have just itemized this down, is that I can not seem to call the height about host level through the built in parameter:
BuiltInParameter.FLOOR_HEIGHTABOVELEVEL_PARAM
It doesn’t return a value. I know I must be doing something wrong here- but I cant put my finger on it. As part of my bigger project- I am making a new floor and then directly once I have made it, I want to be able to check the offset its sitting at for checks and balances.
Thankyou, Sam
> # Enable Python support and load DesignScript library
> import clr
> clr.AddReference('ProtoGeometry')
> from Autodesk.DesignScript.Geometry import *
> # Import Revit API
> clr.AddReference('RevitAPI')
> from Autodesk.Revit.DB import *
> from Autodesk.Revit.DB import FilteredElementCollector, Family
> # Import Manager Classes
> clr.AddReference('RevitServices')
> from RevitServices.Persistence import DocumentManager
> # This gives us access to the document we are currently working in
> from RevitServices.Transactions import TransactionManager
> # Allows us to start transactions to make changes to documnet
> # Import DStype methods ((the revit dynamo nodes)
> clr.AddReference('RevitNodes')
> import Revit
> clr.ImportExtensions(Revit.Elements)
> clr.ImportExtensions(Revit.GeometryConversion)
> # The inputs to this node will be stored as a list in the IN variables.
> dataEnteringNode = IN
> # Place your code below this line
> test = []
> # Assign documnet (the one currently opened)
> doc = DocumentManager.Instance.CurrentDBDocument
> collector = FilteredElementCollector(doc)
> # All genetric
> # Set up Floors
> floor_filter = ElementCategoryFilter(BuiltInCategory.OST_Floors)
> #collected_floors= collector.WherePasses(floor_filter).ToElements()
> collected_floors = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).ToElements()
> for index, i in enumerate(collected_floors):
> if index > 10:
> param = i.get_Parameter(BuiltInParameter.FLOOR_HEIGHTABOVELEVEL_PARAM)
> string = param.AsString()
> #word = offset.AsString()
> test.append(string)
> # Assign your output to the OUT variable.
> OUT = test
