Hi
I’m trying to fetch some intersection points and ended with a list that also contains some lines. How could I filter the lines out the list?
Hi
There are multiple ways to do this, you could use the node List.RemoveIfNot. (Just make sure the input is the exact name of the point-type, use Object.Type to find out what that exact name is).
However if you are looking for intersection/ closest points you could also use the node Geometry.ClosestPointTo to get better results without having to later filter your results.
Thank you, @Daan, but I’m don’t know what I’m missing here.
Glad you got it ![]()
