Filled Region Edge Graphic Style Id
Thanks!
I ended up finding this thread which led me to get that script working.
Here’s the script that is currently working in 22:
# Enable Python support and load DesignScript library
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit import DB
clr.AddReference ("RevitServices")
filled_regions = IN[0]
line_style = IN[1]
def function(filled_region, line_style):
	filled_region.SetLineStyleId(line_style.Id)
	return filled_region
output = None
if isinstance(filled_regions, list):
	output = [function(
		UnwrapElement(a), UnwrapElement(line_style)) for a in filled_regions]
	output = function(
		UnwrapElement(filled_regions), UnwrapElement(line_style))
#Assign your output to the OUT variable.
OUT = output
I have yet to test it in R24, so I may come back to what you’re providing here shortly! :slight_smile:
