File System Name DSCore in Python
Hello I am tring to write this designscript of Dynamo in Python but I get a warning that expects string but got a List.
The designscript pretenting to write in Python
str1 = FileSystem.FileName(t1, false)
the python code I tried
linkNameclean=DSCore.IO.FileSystem.FileName(linkPath)
Hello
DesignScript is not Python :face_with_peeking_eye:
a couple of solutions
import sys
import System
from System.IO import Path
import os
def toList(x):
    if isinstance(x, list):
        return x
    elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
        return x
    else :
        return [x]
lstPath = toList(IN[0])
solution1 = [Path.GetFileName(strPath) for strPath in lstPath]
solution2 = [os.path.basename(strPath) for strPath in lstPath]
OUT = solution1, solution2
yes, but I am able to write it in dynamo python node adding this:
clr.AddReference("DSCoreNodes")
import DSCore
from DSCore import *
Importing DSCoreNodes will import that dll and is NOT Designscript.
I would highly suggest you go with what @c.poupin has said instead of the Dynamo way.
As a general thought on processing time, I would avoid the Dynamo Node method in python when you can use the in built windows way “System.IO” or even the native Python module called “OS”.
Back onto your issue have you tried putting the input items in a for loop with each item then being put into the input?
In addition to @Brendan_Cassidy 's remarks, a quick “time test”
syntax of Python and Designscript are different
