I am creating a BIM from design done by others. I have a large pipe network of an existing water line, which I have split up based on plan annotation of the proposed action to be done to that pipe (i.e. abandon it, remove it, leave it). I use property sets to assign the action, and those PSs do travel with the object thru Data Shortcuts, but for me at least, they don’t update.
As the project moves along, the removed pipes will no longer exist, but the others will. Also the contractor is proposing to abandon more pipes to reduce impact to residents. When doing a visual, I want to be able to manage the styles and visibility, so renaming the pipes is a good option, that travels thru Data Shortcuts.
I wrote this script that works, that reads the action and renames the pipes. I felt I was using Levels too much, and wasn’t sure if there was another way to filter/split the pipes. Also, I’d love to not hard code in the action and need a separate flow for each action. Do you have any feedback or tips on making this one better.
