I have to freeze multiple nodes one by one.
Is it possible to select multiple nodes then freeze them in one click?
Freezing a node freezes everything down stream of it. So, if you freeze the first node you need it will do the rest down stream or dependent automatically.
Thanks, I know I can freeze the upstream node to avoid freezing multiple downstream nodes.
The reason I want to freaze the downstream nodes, because they take long time.
and sometimes I need to view the the results of the midstream nodes, if I freeze the upstream node, I can’t view those results.
Could you maybe show a quick little example of what you want. Not sure I am following completely.
As far as I know, there isn’t a way to group / freeze multiple nodes at a time. Do any of these nodes have outputs and/or are they geometric nodes that you could turn off the preview vs freezing them?
These nodes create elements in the revit, it takes long time to run
One way would be to use a wait or a a single (design script / python) gate node that has two inputs. One of the elements and one input is a bool toggle that you could wire up to each one of the nodes. If you were to freeze the single toggle then all of those when then freeze. Its a bit hackish, but would make it a single point to turn those off specifically.
Would the following be of use once i release this version of DynaStandard?
Note: This version of DynaStandard is currently unreleased as i need to do some QA and update Readme prior to release.
Make sure there are no element bindings as you build the graph. Search the forum for my post on how to do this, or watch the AU session I presented on the topic in 2019.
This package looks extremely useful! Just tried downloading DynaStandard right now and I can’t seem to find the bulk freeze/un-freeze option shown in the video. Did this version ever go live? Thanks!
