Is there any way to access the connector value of a MEP fabrication duct through API ?
Hello @shibujoseukken
here a small example
import sys
clr.AddReference("RevitAPI")
elem = UnwrapElement(IN[0])
conIndex = []
conValue = []
conf = FabricationConfiguration.GetFabricationConfiguration(doc)
connectors = elem.ConnectorManager.Connectors
for c in connectors:
if c.ConnectorType == ConnectorType.End:
connectInfo = c.GetFabricationConnectorInfo()
cn = conf.GetFabricationConnectorName(connectInfo.BodyConnectorId)
conValue.append(cn)
conIndex.append("C" + str(connectInfo.FabricationIndex + 1))
OUT = conIndex, conValue
Hi @c.poupin ,
thanks for your solution, is there a way to set new connector type from drop down menu by dynamo?
I got all the connector available in project, and I am trying to select element and change their connector type by dynamo.
I appreciate if you share your ideas.
to have already tried it seems to me that currently this is not possible via the API
@amirjalaliafshar avoid asking same questions multiple times. You have already asked this here:
Hi @Modeler and welcome.
here is the updaded code
import sys
def toList(x):
if isinstance(x, (list, dict)) or \
(hasattr(x, "GetType") and x.GetType().GetInterface("ICollection") is not None):
return x
else : return [x]
lst_elem = toList(UnwrapElement(IN[0]))
OUT = []
for elem in lst_elem:
conIndex = []
conValue = []
conValue.append(cn)
OUT.append([conIndex, conValue])
It works! Thanks a lot!!
