Hello, I wonder if there is a possibility of getting the superelevation parameters in a range of stations or in a certain station:
- by previously calculating the superelevation with a design criteria
- even if the superlevation is calculated by two 3dpoly targets with and auxliary subassembly ( like white lines in an existing road) and tresspassing this slope to another subassembly in the same assembly. Maybe this method require to calculate a corridor in order to extract the superelevation.
Once you get it, maybe you can write them in a text along a plan view by stations, or extract them by stations in an excel file
Thank you
